Threads: 28
City: Lake Stevens, WA
Hello!
I picked up this beauty yesterday. All she needs is a tune up and new grille cloth.
I really like the style of this big console. Subdued, but elegant. Not in your face, but homey. Real nice wood.
[Image: https://i.imgur.com/CknpFdt.jpg]
[Image: https://i.imgur.com/Hl6Vp3P.jpg]
[Image: https://i.imgur.com/AJ5MfNE.jpg]
[Image: https://i.imgur.com/R0qYcSF.jpg]
Threads: 18
City: Mesa, AZ
VERY NICE!!! VERY NICE, INDEED!!! CONGRATS!!! I suspect that it'll need a bit more than a "tune-up", though. All of these need to be electronically restored to make them safe for daily playing...
Threads: 28
Absolutely! By tune up I mean restoring the components to their original glory.
I have a guy...….a really good guy.....who has been working on these things for decades.
He has done two other old consoles for me, a Sparton 1867 Triolian, and a Zenith Zephyr 6S157. They are pretty much like new after he worked on them.
Threads: 569
A 116X. Great radio.
Threads: 28
Threads: 268
Nice set, good player, excellent sensitivity and selectivity, plays loud!
Aside from the strictly electrical service you may want to have a look at the 2sp dial reduction drive (disassemble, clean, and grease). Under the tuning cap there are 3 rubber grommets that most of the time have failed causing the tuning to seem loose onto the chassis. If so replacement are in order.
I serviced a late model 116B and a 116X (pretty much the same chassis but the B has a smaller output stage as it's a big table model) a couple of yrs ago.
Threads: 416
City: Boston
A great way to start with Philco I have yet to be fortunate enough to find a set on the high end.
Good luck.
Threads: 18
City: Cromwell
State, Province, Country: CT
Nice looking radio! A great find for sure. I have never seen an acoustic damper speaker that big.
Tony
Threads: 28
What is the concept of the dampeners? Are they like passive radiators on modern speakers? I used to have some speakers back in the 80's that had a passive radiator that was front firing, and when I put my ear and hand to it, it was pumping out lows.
Threads: 18
City: Cromwell
The way I understand these work is by absorbing vibrations and other anomalies caused by the cabinet leaving clear true sound representation. I don’t have first hand experience with them yet till I get my 38-690 done. I’m tempted to pull them out to see what changes they make, an experiment.
Tony
Threads: 268
If you've done any web research on the 116X you've probably seen this: http://www.tuberadioland.com/philco116X_main.html Excellent write up and mentions the ac. There has been a lot written over the years about the ac. Some have said it's junk science or that it's just sale gimmick. At the rear the center of the cone is fitted with rubber strap to dampen the cone's movement. A lot of these look like they melted sort of droopy. Someone wrote a piece about replacing the rubber strap with a section of plastic wrist band. It looked ok but not sure if it would respond in the same manner as the rubber would have. As for the ac's in general personally I don't know what the performance is like with or without I've never done a test.
I must admit that I have thought of removing the two small ac and replacing them w/a pair of tweeters.
Threads: 28
My radio tech guy is going to also be replacing the grille cloth for me when he goes through it. If I am correct, I think this is the correct grille cloth for me to order.
http://www.radiodaze.com/grille-cloth-41...c41-25x25/
Threads: 18
City: Mesa, AZ
That's odd. That is the cloth I used in the 38-1. Yours being a 1936 model, you would think they would have a different patterned repro cloth for that. I would double check that one...
Jim
Jim (Electro) is correct - you don't want to use that cloth in your 116X. You should use this instead:
http://www.radiodaze.com/grille-cloth-03...c03-18x25/
or better yet, more authentic looking, the "Philco Chevron" on this page:
http://richmonddesignsinc.com/grille_cloth_product_page
Threads: 28
Are you sure about this guys?
Here is a pic of the cloth on the Philco. It looks more like GRC-41 to me. Two dark lines on a lighter background. The other one looks more like two lighter lines on a darker background.
also, if you look at this page, it looks more like the one I'm talking about. It's light background with darker twin stripes.
This is my 116X grill cloth.
[Image: https://i.imgur.com/zrpvbpf.jpg?1]
(This post was last modified: 06-07-2018, 07:24 PM by rdnzl.)
Users browsing this thread: 36 Guest(s)
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
There are currently 4111 online users. [Complete List] » 2 Member(s) | 4109 Guest(s)
