1936 Clinton 216 radio - lots of questions!
Hello all.  I've acquired a 1936 Clinton model 216 table radio built by the infamous "Plant A" in Chicago.  Currently it is a basket case, having been in a basement flooding.  I'll have to completely rebuild the cabinet.  My questions are ...  Is it worth the effort?  Was this a desired radio, or just a mass produced throw away?   Radiomuseum has photos and a schematic available.  I haven't worked with them before and I'm curious if they are a legit source for the information I need.  Anyone out here ever deal with them?  This radio used a line voltage ballast tube (K49C).  How does one go about testing one of these?  I've never dealt with them before.  Sorry I don't have any pictures to post yet, but the radiomuseum file has a few.  I'll post some if I decide to tackle this project.  Thanks guys!  Take care, Gary
Your ballast tube is a couple of high wattage resistors in a can.  Should read about Pin 3-8  132 Ohms, Pin 7-8  84 Ohms if good. It's used to drop the 120v ac line down the the appropriate heater voltage (49v @ 300ma)to power the series strung circuit. This means that the total of the tubes heaters should come to about 76v. = two 25v tubes and four 6v tubes.
Thanks, Terry.  I'll check this evening after dinner.  Anyone have any input regarding "Plant A" radios?  I've found little information, but it went from junk sets to cutting edge technology!  Quite the secretive company.  Take care, Gary
Joe Rossi is a wealth of knowledge.
Maybe he can chime in.
Post pictures of cabinet, it may not be as bad as you think, though the Plant A sets did tend to be cheap series string models. Your main issue would be finding a schematic if it doesn't have one posted inside the cabinet, I'm not sure if Clinton sets were listed in Riders.
Hello Arran,  I was able to get the schematic for the set from Radiomuseum.  As far as the cabinet is concerned, it was in direct water contact and most of the veneer separated and curled away.  What's left has some pretty hefty warpage.  Take care, Gary
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
There are currently 2687 online users. [Complete List]
» 2 Member(s) | 2685 Guest(s)
