1930 Philco 20B Cathedrals
Threads: 91
City: Jonesboro
State, Province, Country: AR
(06-08-2018, 11:00 PM)Ron Ramirez Wrote: +1 what Terry said.
For what it's worth, all of the dogbone resistors in Model 20 are 1 watt. Some, such as the 500K, are overkill. Philco simply did not have anything smaller in wattage at the time.
1/2 watt resistors did not start to appear in Philco sets until 1931.
Thanks Ron.
I usually keep 1W on hand, so that's what will go in. May be overkill, but at least they'll stay cool.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 91
City: Jonesboro
I just rebuilt the big can capacitor. It went fairly smoothly for my 1st time doing one of these.
[Image: https://farm2.staticflickr.com/1829/2901...8989_k.jpg]
The concern I have is there was a noticeable amount of tar that had leaked out onto the top of the chassis. I'm hoping it came from the cap can, and not the main transformer.
I was able to clean it up.
Does anyone have the ohm readings for the various windings on this transformer, so I can check if they are all good?
It's not indicated on any of the paperwork I have.
Here's the schematic for reference.
[Image: https://farm2.staticflickr.com/1765/4198...e442_h.jpg]
Any help or tips welcome and appreciated.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 268
Would worry too much abt the resistances. There are a few things you can check. Smell around the bottom of the transformer under the chassis. Does it smell burnt? Remove the 80 tube and measure the ac voltage from terminals 6 and 12 and then 6 and 9. Voltages should be pretty close + or - 10v. Bad transformer will have a large difference between the ct and one end. Typically lv windings aren't an issue if the hv filters short, they take out the hv winding. With 80 tube removed plug in the set and leave in on for 10 or 15 min. Have a look at the tubes heater to be sure they are lit. Don't think the early model 20's had a dial lamp. Transformer should feel pretty close to room temperature. If it is warm, hot or smoking. That not a good sign.
Threads: 91
City: Jonesboro
Terry,
Thanks for the tip. I did as you suggested. All tube filaments light up, no excessive heat or unusual smells, so I plugged in the 80, and turned it on.
I hear a low hum, and a pop, and then next to no audio. I do hear faintly our local 50Kw talk station at 580 AM on the dial, and that's it.
I have yet to measure voltages.
I did pull the tuning coils- IF and RF, and put new grid cap wires on them, and check the coils. They all appear to ohm out to what I believe to be appropriate resistances.  (I had the same issue of no stations before I did this, so I thought it might be one or more coils, hence my pulling them.)
All the dog bone resistors were pulled and new ones installed since they had all drifted out of spec.
My only concern is what I believe is the Output transformer or choke. (Part 21 on the schematic.)
I get uneven readings on the 2 sides. On the input side I get 1300 Ohms. On the output side, from one 71A to the other, I get 6.35K ohms. Measuring to the tap, I get 3.48K ohms on 1 side, and 2.9K ohms on the other side.
Also, my 71 tubes don't match. 1 is an ST style, the other is an older globe. Although they both check out strong on my tube tester.
I'll check voltages and report back.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 91
City: Jonesboro
OOOPS!!!
I pulled my Philco 20 chassis, and put them up side by side to start testing and comparing values.
I discovered a mis-wiring. I had to replace the dog bone resistors. I did it at the same time as re-stuffing the bakelite blocks.
I got the connections on a couple resistors wrong when reconnecting everything.
I guess I'm getting old. I really need to stop working by memory and start marking everything.
She's up and running!
Now to align it.
Blessings,
Jeff W.
Jonesboro, Arkansas
Threads: 268
No if or osc in this one as it's a trf.
Glad to hear you got it working!
Threads: 5
City: Woodland, CA.
Sorry to interrupt guys,
the transformer test mentioned earlier got my attention. Would this be a safe test for my 16b? No speaker and the filter cap wires have crumbled but i really want to make sure the power trans is up to snuff.. Will a removed #80 work here too?
Thanks..
Threads: 268
Should be fine to test in the same manner w/the 80 removed.
Threads: 5
City: Woodland, CA.
Thanks Radioroslyn, It worked out fine, Power transformer measured good, and ran cool.
"We now return to 20B cathedrals, already in progress"..
Threads: 35
City: Tulsa, OK
so this means there will be no capacitors on terminal 5 and 6
Threads: 35
City: Tulsa, OK
Threads: 268
5 appears to be unused or is a tie point. 6 has a.13 cap connected to it.
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 4002 online users. [Complete List] » 3 Member(s) | 3999 Guest(s)
