Philco 52-542-1 totally dead
Threads: 1
City: Anacortes
State, Province, Country: WA
I just acquired a Philco 52-542-1 and upon initial inspection, the chassis is clean, no rust...the tubes all test very good, none are at all weak...the original caps, resistors and electrolytic cap look new....when i plug it in, not even the dial lamp illuminates and the bulb is good and works independently...not even the tubes warm up.....no sound, nothing, everything is cold......the power cord is in good shape, no breaks or cracks and is fully intact underneath.......any thoughts would be appreciated as to where I should start.......not even having the dial light come on, let alone everything else, is a curiosity....I suspect I need a new volume pot which is part number 33-5566-4 or equivalent at 500,000 ohm
Threads: 8
City: S. Dartmouth
State, Province, Country: MA
Confirm your suspicions, check the continuity of the on/off switch. Try a non-flammable contact cleaner inside the switch and turn on-off many times, this may restore continuity.
Chas
Pliny the younger
Threads: 30
City: Wellborn Florida
Looks like a nice AC/DC set.
Threads: 569
A 1952 radio, young it be compared to 1930-s sets, still requires recap, especially electrolytics which dry up no matter the looks.
Before you do this, I strongly discourage you to power it up.
The radio being AC/DC set, the lamp and tubes not glowing means there might be a tube with open filament. Check the tubes. Also if there are loctals, their pins oxidize - need to be scratched.
Threads: 30
May I ask what is the number of the dial lamp? David
Threads: 416
City: Boston
Kind of a neat looker. The recap is a must.
Threads: 242
City: West Bend, Wisconsin
Most of these sets use a #47 dial lamp bulb
Here's the schematic pages from Nostalgia Air, which includes the parts list:
http://www.nostalgiaair.org/pagesbymodel...013741.pdf
Threads: 3
City: Chesapeake VA
Only a simple ohm test of switch in on & off positions is necessary to verify continuity.
Assuming only one dial lamp, bayonet base bulb should always be #47 or #51. If mfgr used something of higher current, they are outside the original design of 35Z5. This is not to say one can't fudge a bit.
BTW there are many later type bulbs that are 6.3v@150ma. Numbers #130, 755 & 1847 come to mind, any of these could be used.
Tom
(This post was last modified: 06-27-2018, 10:12 AM by 35Z5.)
Threads: 30
The reason I asked the question about the number of the dial lamp I have found some very creative work when folks did not have the correct bulb. One set had a appliance bulb installed at the back of the set but with a 15 watts bulb you could see the dial, even when the set was turned off, radio and night light combo.
(This post was last modified: 06-27-2018, 05:24 PM by David.)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
There are currently 5983 online users. [Complete List] » 1 Member(s) | 5982 Guest(s)
