Matching Output Xformer to Spkr
I've never seen this addressed before but when calculating the voice coil impedance in order to find a matching output xformer, don't you need to also include the hum bucker coil impedance in series with the voice coil? I recently dismantled a speaker and the hum bucker was separate on the pole piece. It had a decent amount of wire in that coil, surely enough to affect the overall impedance! Thanks
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Well...yes you do. However I think compared to the voice coil the humbucker which is a much thicker wire coil shouldn't amount to too large a percentage. In addition the voice coil impedance is larger than its mere DC resistance as there will be the inductive component.
Plus when you replace the transformer it will likely be a good enough match, not an exact one.
Thanks Mike. I've seen some speakers listed with impedances of an ohm or two. The hum bucker coil I saw had a fair amount of windings so I'm thinking it would account for a fair amount of the total including voice coil.
Ron
Better yet, early Philco speakers are fractions of Ohm.
The speaker table error?
Philco 70 antenna lead
There are currently 6137 online users. [Complete List]
» 1 Member(s) | 6136 Guest(s)
