Philco 41-315 Code 121 Pilot Lamps?
I am working on a Philco 41-315 Code 121. The pilot lamps are Push Button, Band Indicator - 34-2141, Scale Lights - 34-2064, and Cabinet - 34-2210. The bulbs are very difficult to remove. Any suggestions on how to remove the bulbs from the sockets would be greatly appreciated. Where do I find the information on the actual bulb numbers?
Thank you,
nv3g
Oscar
I had same problem on a Philco 38-3.  After reading Ron's article on rebuilding pilot lamps (see link below), I used a heat gun to soften the rubber so I could then extract the bulbs.  Can't help on the bulb numbers.
http://philcoradio.com/phorum/showthread...pilot+lamp
Larry
All of your philco numbers crossover to #44 bulbs.
Thank you both for your prompt replys.
nv3g
Oscar
The speaker table error?
Philco 70 antenna lead
There are currently 2072 online users. [Complete List]
» 2 Member(s) | 2070 Guest(s)
