Philco speaker substitution question.
Hi everybody,
It's been a while since I actually posted a question here, but post a question here, I will. :-)
Will a speaker from a 40-150 fit a 41-255 radio?  Both radios use two #41 output tubes in a push/pull configuration.  I don't actually have the 40-150 speaker so I can't physically or electrically check to see if it will fit and work.  I've got a 41-255 that needs a speaker.  Any thoughts or advice?
Thanks a lot, Tom
Hi Tom,
Electrically they look to be the same the opt and fc as for the physical not sure.
The speaker table error?
Philco 70 antenna lead
There are currently 2116 online users. [Complete List]
» 2 Member(s) | 2114 Guest(s)
