41-295 Tube Substitution/Antenna
This radio came to me with a 7C7 in place of one of two 7B7's. Is this a useable substitute? The sub lists I have looked at say yes and no.
http://www.nostalgiaair.org/pagesbymodel...013422.pdf
pretty much the same
yes it will work
Thank you. Also, as the antenna is missing, I would like to duplicate the original. Can anyone describe it, or have better pictures than RadioMuseum?
91H Code 126 Restore
