Threads: 76
City: Winter Haven, FL
I think I'm missing something here. I'm feeding a 455Hz signal in to troubleshoot. I get a good strong signal to the voulme control, and also on the top of C424 (.006mfd). But I get nothing on the top side of R419 right above it. Resistor ohms out just fine. Anyone lead me in the right direction? I hope this schematic is readable. Thanks.
[img] [Image: http://i1367.photobucket.com/albums/r796...jhkvn7.png][/img]
Threads: 569
C423 shorted?
Threads: 76
(09-03-2018, 05:07 PM)morzh Wrote: R423 shorted?
Did you mean C423?
Threads: 569
Yes, I did.
Threads: 76
No, C423 is O.K. I just checked it even though it's new.
Threads: 268
I'm missing something too. If you apply a rf signal to the volume control you shouldn't hear it. The rf signal must be rectified to covert it to an audio signal. If you want the use rf @ 455kc connect it to the control grid of the 7H7 (p6 I think). Make sure your mode switch is good and clean.
(This post was last modified: 09-03-2018, 08:38 PM by Radioroslyn.)
Threads: 569
What I did not appreciate was it was 455kHz. C423 simply shorts it.
Threads: 76
(09-03-2018, 08:37 PM)Radioroslyn Wrote: I'm missing something too. If you apply a rf signal to the volume control you shouldn't hear it. The rf signal must be rectified to covert it to an audio signal. If you want the use rf @ 455kc connect it to the control grid of the 7H7 (p6 I think). Make sure your mode switch is good and clean.
I'm using an Eico 324 RF generator with internal modulation AF out, not a strict RF signal. I just finished recapping the chassis and am in the process of alignment. Guess I should have explained that. Sorry. I'm working backwards from the amp section to find out why I'm not getting audio.
Threads: 76
(09-03-2018, 08:59 PM)morzh Wrote: What I did not appreciate was it was 455kHz. C423 simply shorts it.
It's AF modulated RF. I used to use a "Mosquito" for tracing. Remember those?
Threads: 114
City: Sneedville, TN
I restored a 48-482 back in 2014. The toughest part was aligning the FM converter, but it can be done using a regular modulated sig gen if you carefully follow the instructions in the Philco service paperwork, it tells this alternate method. You may find my thread on this project of use. http://www.philcoradio.com/phorum/showth...?tid=10134
Threads: 76
Read through your thread. Might be some useful information there if I ever get through the BC part.
Threads: 569
Patrick
Where exactly is it that you feed the IF signal to?
I am still not sure.
Threads: 76
(09-04-2018, 08:46 AM)morzh Wrote: Patrick
I took a step back, and used the Philco troubleshooting guide. I have a strong IF signal at the grid of the 1st IF amp. I have only a very weak signal at the plate of the converter. That would indicate a problem at the 1st IF transformer, Z400. So it appears the problem most likely is there, and I was just going off on a tangent somewhere.
Threads: 76
Found the problem! Z404, a choke/cap combination, was wired to the white lead on Z400 instead of the green lead. The two connection points are right next to each other. That caused a very weak signal from the plate of the converter. Connected it properly, aligned the IF, and picks up stations. I really think the stock speaker is too small for this radio.
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
91H Code 126 Restore
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
