1930's Philco antennas
Has anyone here actually installed one of the 1930's Philco antennas? I'd be very interested to hear about how one performs.
Good question.  I have a few extra and am considering installing one as well.  I understand the height and length would increase short wave reception the most.
Very nice Paul.
I only have one from 1938 but was wondering as there seems to be a lot of them available. The price seems to be competitive with buying a new long wire antenna and the idea of using a 1930's antenna seems very unique. Especially with a Philco radio   Icon_smile
Wytex do you have a picture of one of these? I don't even know what they look like. I have a 1933 and a 1940 Philco and might be interested in seeing if I can find one or two, but I need to see what I am looking for. Thanks!
Gregg Icon_thumbup
Here are a couple of references to those antennas:
https://web.archive.org/web/200402081258...0-6112.htm
http://philco.firecaster.com/Additional.htm
Awesome, thanks Bob!
Gregg Icon_thumbup
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2741 online users. [Complete List]
» 1 Member(s) | 2740 Guest(s)
