HELP Need a Philco expert
Hi all. I have a 71 cathedral that is beautiful but quite silent.  I can't seem to get it to oscillate at all. I have rewound the primary (small outer coil) on the oscillator coil but it still won't play.  This radio actually belongs to a customer of mine.  I have completely recapped it and checked all the resistors and tubes.  If someone can take a look he will pay you what ever it takes. Thanks.
If it glows in the dark and heats up the house its MY kind of radio!  Icon_crazy
So are you looking for troubleshooting help to fix it yourself or someone to fix it?
I really want to send the chassis and speaker to someone who can take a close look at it and find the problem.
Has the chassis been recapped and checked otherwise the way it's supposed to before power-up?
Yes. I checked it out. The amp works fine, just won't oscillate.
(09-24-2018, 12:44 PM)sumnerplace Wrote:  I really want to send the chassis and speaker to someone who can take a close look at it and find the problem.
If you do not feel comfortable working on it yourself, then you should do the following:
1. Place an ad in the "Wanted Ads" section of the Phorum.
Go to the Phorum home page - scroll down - keep scrolling until you are close to the bottom of the page - you will see For Sale or Trade and Wanted Ads.
2. Use the Resources pages here in the Phroum to find a radio repairman near you.
Look under Philco Info > Philco Resources.
I see you are in Washington state. There are two radio clubs in your part of the country - Puget Sound Antique Radio Association and the newer Inland Empire Antique Radio Society. Contact one (or both) of these clubs and see if they can recommend someone close to you that can work on your radio for you.
http://www.pugetsoundantiqueradio.com/
http://www.iears.org/
Thanks Ron. I'll do that
Ron I can't find the Philco Info page or the Resources page. Can you help me?
http://philcoradio.com/phorum/showthread.php?tid=14951
http://philcoradio.com/phorum/showthread.php?tid=14950
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3561 online users. [Complete List]
» 2 Member(s) | 3559 Guest(s)
