Philco Shadow Graph Rebuilt With Arduino
Threads: 18
City: Ann Arbor, Michigan
(This post was last modified: 09-25-2018, 09:48 AM by markmokris.)
Threads: 268
Clever idea.
For me it's just easier to rewind the original.
Threads: 18
09-25-2018, 01:31 PM
I was looking for something to use an Arduino for.
Mark
Threads: 569
What's in the blue box?
Threads: 4
City: Monteith, Ontario CA
(09-25-2018, 02:10 PM)morzh Wrote: What's in the blue box?
I don't know but I'd guess a signal controlled motor to adjust the vane of the indicator.
Threads: 569
I thought it is a motor, but was wondering how fast the reaction would be: it needs to be very fast.
Threads: 54
It's likely sluggish compared to the original movement, which was just a form of variometer like an analog Ohm or Volt meter, which just moves with changes in AGC voltage rather then having to think about things first.
Threads: 569
you mean - galvanometer? It's a crude form of Weston/D'Arsonval galvanometer, indeed used in all analog meters.
Threads: 4
(09-25-2018, 04:46 PM)morzh Wrote: I thought it is a motor, but was wondering how fast the reaction would be: it needs to be very fast.
They can be very fast. All of the gasoline powered inverter generators that I have worked on use the same sort of system for engine speed control, and that has to be at least as fast as this indicator.
Threads: 569
I hope so.
Motor is not as reactive. It takes more time for the engine to rev up, then for a human hand to pass the station when rotating the dial while looking at the indicator: the angular speed could be quite high even with slow rotation, and very little needed to pass the tuning point.
Threads: 18
It's not a great solution. It is a little slow, and you can even hear the servo make a bit of motor noise as it turns. The servo, the little blue thing, takes commands from the Arduino microcontroller to turn to an angle between 0 and 360 degrees. I did it as more of a novelty than anything else.
I am usually one for authenticity, and this is reversible if I get a working shadow meter. I tried rewinding the coil twice, and I couldn't seem to get t to work very well.
Mark
Threads: 569
Have you tried to re-magnetize the magnet?
Threads: 54
A Galvanometer, yes, that's the word, I must have been a bit off when I typed that. But still, the shadow meter movement should react much like a magic eye tube if it's working properly, charging up the magnet is a good idea.
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 2467 online users. [Complete List] » 1 Member(s) | 2466 Guest(s)
