Sad looking RCA T6-1
I picked up this 1935 RCA tombstone at the last WARCI meet on September 16. It was only $20 so I figured what the heck, I'll give it a shot. Once I was able to get the radio playing again after a complete recap, some resistor replacements and two tubes, I knew I had to tackle the cabinet. Needless to say, it was a real veneer replacement challenge, but all in all I think it turned out fairly well. Far from perfect but a whole lot better than it was. Icon_thumbup
Before:
After:
Before:
After:
Before:
After:
Beautiful work Greg. I think you did an excellent job on the veneer replacement. Icon_thumbup
Icon_clap Icon_clap Icon_clap
nice work!
Very nice work.
Greg,
You did a great job! Icon_thumbup Icon_thumbup
Greg super  job!!! You saved it to be played again... And we thank you for that.  Icon_thumbup
Nice save Greg Icon_thumbup
Very nice, Greg!! Nice to see a near junker pulled away from the flames!
Fantastic workmanship,,,,,
Very nice work!
Looks fantastic perhaps better than new?
You said it, brother!
A real beauty.  Great work!   Icon_clap
Joe
Thanks, everyone. It was definitely a challenge!
There are currently 11400 online users. [Complete List]
» 2 Member(s) | 11398 Guest(s)
