veneer banding
Where is best place to get 3" veneer banding ? Or maybe good looking 3" decals .
Thanks Denver. Icon_wink
http://www.constantines.com/poplarcrossbanding1.aspx
M R Radios   C M Tubes
Yea just what i need . Thanks a lot . Icon_biggrin
Kent.
There are currently 8512 online users. [Complete List]
» 2 Member(s) | 8510 Guest(s)
