chassis insulator bushings Rockauto.com
Threads: 46
City: Gap Mills Wv 24941
i am pretty sure these are a direct fit to most of our radios with rubber insulators with a metal internals.
I also bet these will last way longer than other types and the price is unbeatable at rock auto.
https://www.rockauto.com/en/moreinfo.php...09&jsn=609
Threads: 112
City: Medford OR (OR what?)
Cough - -cough - -I feel sick already and I only looked at the web page:
" WARNING: This product can expose you to chemicals including Acrylonitrile, which are known to the State of California to cause cancer and Phthalates which are known to cause birth defects or other reproductive harm. For more information go to www.P65Warnings.ca.gov."
Threads: 46
so, with such a high altitude, what is your net gain at my expense?
Threads: 112
? were you asking me?
Threads: 112
(10-14-2018, 02:24 PM)jcassity Wrote: so, with such a high altitude, what is your net gain at my expense?
If so, you will need to clarify.
Is that your site?
Threads: 46
no, its not my site, its as the topic title and site says,, its RockAuto.com
its interesting that your quote implies the radios we deal with are naturally aspired to be non-toxic. it made no sense, yet it does in a way since a very small amount of the population whines and cries loud enough to force the rest of us to comply with the state thats anti everything to include those permanent residents in Arlington cemetery.
i did not need the body slam when finding a 3 pack of insulators for a dollar then sharing here.
Threads: 112
(10-17-2018, 10:14 AM)jcassity Wrote: i did not need the body slam when finding a 3 pack of insulators for a dollar then sharing here.
I still don't understand this comment. The quote is from the site that you posted. I really don't see why you would take this personally.
Calm down, guys.
Scott, in Russ' initial post in this thread, he was merely joking about something stated on that page you linked to regarding certain chemicals and the state of California. I did not read it as anything personal against you, and I do not believe Russ intended it as such.
Threads: 112
(10-17-2018, 10:14 AM)jcassity Wrote: no, its not my site, its as the topic title and site says,, its RockAuto.com
I did not imply any such thing.
Are you sure that you want to suggest that SOMEONE ELSE is whining and crying about something? BTW your comment violates forum rules.
P.S. The most ironic thing is that I was implying exactly what you said - without breaking the rules.
(This post was last modified: 10-17-2018, 11:14 AM by Phlogiston.
Edit Reason: P.S.
Threads: 271
City: Wilsonville
State, Province, Country: OR
Folks, its easy to misunderstand people in these written phorums since we have no visual cues to realize someone is trying to make a joke. That's the way I also read Russ's comment but understand that it could be read differently. In any event, let's all just calm down as Ron suggested, this is a phriendly place..this thread is closed.
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 2717 online users. [Complete List] » 2 Member(s) | 2715 Guest(s)
