1930's Philco antennas
Has anyone here actually installed one of the 1930's Philco antennas? I'd be very interested to hear about how one performs.
Good question.  I have a few extra and am considering installing one as well.  I understand the height and length would increase short wave reception the most.
Very nice Paul.
I only have one from 1938 but was wondering as there seems to be a lot of them available. The price seems to be competitive with buying a new long wire antenna and the idea of using a 1930's antenna seems very unique. Especially with a Philco radio   Icon_smile
Wytex do you have a picture of one of these? I don't even know what they look like. I have a 1933 and a 1940 Philco and might be interested in seeing if I can find one or two, but I need to see what I am looking for. Thanks!
Gregg Icon_thumbup
Here are a couple of references to those antennas:
https://web.archive.org/web/200402081258...0-6112.htm
http://philco.firecaster.com/Additional.htm
Awesome, thanks Bob!
Gregg Icon_thumbup
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Philco 91 Restore Code ??
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
So sometime  back I posted some photos of a badly damaged in transport T62, not the tank. I did manage to get a donor c...Paul Philco322 — 05:43 PM
There are currently 2762 online users. [Complete List]
» 2 Member(s) | 2760 Guest(s)
