Corrected doc to align 40-195, 40-200, 40-201
Here is a corrected document on the procedure to align the 40-195, 40-200 and 40-201 receivers.
Step #2 and #4 said to adjust 29B but it should be 25B instead.  There is no 29B adjustment.
Denis R.
91H Code 126 Restore
There are currently 4944 online users. [Complete List]
» 1 Member(s) | 4943 Guest(s)
