Philco 38-3 Dial Removal
How do I remove the metal plate in front of the dial so I can replace the dial?
Chuck has some info on his repair bench site: http://www.philcorepairbench.com/auto-tuning-dial/
and the Service Bulletin# 273: http://www.philcorepairbench.com/wp-cont...ervice.pdf
I've never worked on one of those but I'm sure someone here has ...
You may find this   http://philcoradio.com/phorum/showthread.php?tid=13848  helpful too.
Thank you both for the quick response and clear instructions.
91H Code 126 Restore
There are currently 4964 online users. [Complete List]
» 1 Member(s) | 4963 Guest(s)
