2nd IF Transformer Question
Threads: 22
City: Kewanee
State, Province, Country: Illinois
Good morning all, I’m working on my 60L and have been going though the transformers. Yesterday I rewound the primary on the oscillator: The antenna looked and tested great. The 1st IF tested to the specs on the schematic, but the 2nd IF tested bad unless the schematic is incorrect. It shows values of 34 ohms and 85 ohms and mine tests out at 35 and 46. Is the 85 on the schematic incorrect or is the one winding bad? If it is bad can I rewind it? If so what size wire and how many turns? Thank you!
Gregg
Threads: 112
City: Medford OR (OR what?)
I would test it in operation prior to doing anything else. It is probably OK. They are tough to rewind.
Threads: 22
City: Kewanee
Thank you sir, that’s what I will do then. What symptoms would I see if it is not great?
Gregg
Threads: 112
It will either work or it won't. Won't meaning - No or very low level to the 2nd detector stage - unable to tune.
That kind of winding on a secondary can sometimes have corrosion problems but there isn't usually much current so they don't burn open like a primary. SOMETIMES the tuning (caps) can be the problem.
Threads: 569
It is rarely n RF coils that there's continuity and it is bad.
Threads: 22
City: Kewanee
Ok, sounds good. I’ll see how it does once I get it all back together. Thank you both for your input.
Gregg
91H Code 126 Restore
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
Philco 70 antenna lead
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.Jim Dutridge — 04:34 PM |
Well I'm making good progress.
All the bakelite blocks have been recapped. I found that using a heat gun and skinny ...RealRider — 02:35 PM |
There are currently 3616 online users. [Complete List] » 2 Member(s) | 3614 Guest(s)
