37-650 shadow meter installation.
After many trials and tribulations with this unit, it plays perfect, the cabinet has been professionally redone, and I come to the last item putting the D**n thing back in the cabinet. The radio, with new chassis grommets fits perfectly, but I cannot seem to figure out how to re-install the shadow meter. When using the clips in the cabinet - it does not seem as if the radio will slide in correctly.
[Image: http://antiqueradios.com/gallery/d/121548-1/fit.JPG]
Your escutcheon is upside down.
The clips that hold the shadow meter in place are at the top rear of the escutcheon.
Oooopsy Icon_biggrin
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
