Philco plastic dial covers
Hi all, Had 2 Philcos that needed new dial covers. Found a site by Eddie Brimer that gave instructions on how to make your own. It works very well! The first was 47-205 which was my first attempt-took me 3 tries to get it decent. Make sure EVERYTHING is clean-One small unseen speck of dust shows up on the new dial cover! Found out the 1/8" stock I was using did not produce the original depth of the dial cover. Used 1/4" stock and that turned out fine. The second was a 38-14 and the 1/8" stock was perfect for this radio. I am pleased with the results and want to thank Eddie for providing the info. My wife is used to me putting radio stuff in the oven now that I have gotten my own cookie sheets to put stuff on-I ruined most of her original ones which I have replaced! Kenny Kidd
How about posting a few pics here so we can see? Icon_smile
What is the web site address? I need to do at least one...
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
Here, in this messge thread. See the FAQ link at the top of the page. Then go to the BBCode faq.
I'm not finding it, Chuck- or am I missing something?
Scott
Scott, are you referring to this?
http://members.aol.com/EB062559/DIALCOVERS.html
Yes! Perfect! Thanks, Ron!
Scott
Philco 91 Tuning Condenser
There are currently 9714 online users. [Complete List]
» 1 Member(s) | 9713 Guest(s)
