ATWATER KENT 82
Buenos días,
Estoy restaurando un ATWATER KENT, modelo 82. Una de las piezas que faltan es el potenciómetro. Es un potenciómetro con un interruptor de 550 ohmios.
¿Podría alguien aconsejarme dónde encontrar el componente? ¿Original o similar?
Gracias y saludos,
Ferran
Ferran, prueba con Mark Oppat.
http://www.oldradioparts.net
Muchas gracias !!!!
Agradecido.
Saludos cordiales,
Ferran
La página web que me has pasado, fantástico.
El viernes me enviará el potenciometro.
Gracias de nuevo.
What? English, please!
Select all (highlight the text)
Right click
Translate with Bing
All fixed
+1 what Russ said. Nevertheless, while I savor a just-finished delicious Thanksgiving dinner and let the tryptophan do its thing...and since I feel good enough today to do this...Ed, let me translate the entire exchange for you.
Ferran Wrote:Good Morning,
I am restoring an ATWATER KENT, model 82. One of the missing parts is the potentiometer. It is a potentiometer with a 550 ohm switch.
Could someone advise me where to find the component? Original or similar?
Thanks and regards,
Ferran
morzh Wrote:Ferran, try Mark Oppat.
Ferran Wrote:Thank you !!!!
Grateful.
Best regards,
Ferran
The web page that you have passed me, fantastic.
On Friday I will send the potentiometer.
Thanks again.
Icon_smile
He says Mark's website is great and on Friday his pot wll be mailed to him.
The guy is from Spain and in Spain English is not widely spoken.
Good morning,
I apologize to all. Excuse me !!!
In the rush I had not noticed.
And I take this opportunity to wish you a happy Thanksgiving party. I know it is very popular in your country.
Best regards,
Ferran
No problrm.
Thanks
We are a couple of hrs. behind on the turkey (West Coast time).
