looking for a glass front for this philco the restoration people who cleans up after a house fire broke it so if I can't find one how much should I get from them? thanks Greg.
Hello,
This is an old post but just in case... I have one of these in perfect condition. But on the internet I see another similar type. I'll send a phot of mine if you are still looking.
Harold
There are currently 8762 online users. [Complete List]
» 3 Member(s) | 8759 Guest(s)
