unknown console
Smile
hello friends   Icon_biggrin
 I was not able to find brand of this console ! It has lost its radio and no label inside the cabinet Icon_sad
Does somebody have an idea ??  Thanks a lot for help
[Image: https://forum.doctsf.com/uploads/default...75x500.png]
Looks like a radio with SW converter. Philco, Stewart-Warner, Westinghouse made them, some others too.
It's a very pretty cabinet and would look nice restored. Icon_smile
Gregg Icon_thumbup
