RCA 61-8 Output Transformer
I have a RCA 61-8 that I'm doing for a friend and the output transformer is open, the thing is it has three leads on the primary in stead of two. The print shows a tap and 9 ohms. I usually use a PT-291 from AES as a replacement, Will this work? What do I do about the third lead how can it be connected or can it?
http://www.nostalgiaair.org/pagesbymodel...015046.pdf
Eric
You don’t need a transformer with the tap if one is not readily available. Any AA5 OP transformer will do. Take a look the the schematic I attached. It is a simple radio with only the 1.5K resistor between the two filter caps and no tap. The transformer input would connect to the rectifier cathode and output to the OP tube plate on your set.
http://www.nostalgiaair.org/pagesbymodel...007666.pdf
Tony
Yup, I found a old output and hooked it up and and it does work now I have to find a smaller one that I can fit in not a lot of room. Thanks
Eric
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 2472 online users. [Complete List]
» 4 Member(s) | 2468 Guest(s)
AvatarAvatarAvatarAvatar
