dial stringing Philco 42-345
Does anyone know where I can get a diagram to restring my Philco
42-345 radio? Thanks, Phil
Phil,
Yours may be the same as a 42-350? Go to "theoldradioguyfixerupper.com" and look under his dial stringing guide. May be # 357!
Good luck, John
Quite a few people have been looking for dial stringing diagrams for Philco 42-340 & 42-345 lately. Let us know if the 42-350 diagram is the same, OK?
I know this is an old thread, I too am looking for a dial string guide. The web site that is mentioned here doesn't exist anymore. The radios that are mentioned here are not on Sams list.
Jim
Spring Lake MI
I found that the 42-350 is the same. I found it in the Philco Library schematic for the 42-350. It had a very small diagram. The dial string is pretty straight forward anyway.
Jim
Spring Lake MI
Here's the link to that schematic and dial string for the 42-350 Jim mentions:
Eico 232 VTVM Schematic
