1941 Philco escutcheon Screws
I've trying to find the small Bronze colored oval head screws that attach the plastic dial cover on the 41 philcos. I've tried to use other screws , but they just do not look right.
Any suggestions ?
Try Restoration Hardware...... http://restorationhardware.com/
Probably one near you. See their Store Locator.
Chuck
Unless you live in a large metropolitan area, you may be out of luck on finding a Restoration Hardware store. I checked my area...closest Restoration Hardware stores to me are in Indianapolis, Cincinnati, and Nashville. They aren't even in Louisville! Icon_sad
The closest one to me is in near Orlando, about a 100 mile drive.
So far I found some HO model train track screws that don't look too bad.
Thanks for the info.
Al
I have seen these screws at local hardware stores; I think I have even seen them at Lowe's. I bought some a while back to replace some screws on an early 1940s Philco escutcheon, but I don't remember where I bought them. Must be getting old. Hmpf. Icon_confused
There are currently 9693 online users. [Complete List]
» 1 Member(s) | 9692 Guest(s)
