42-1008 Code 122
I am restoring a#42-1008 code122 ,this is a very unusual cabinet that was covered in leather and poles by the famous furniture maker Thomas Molesworth. It recently sold at a Sothebys auction . It is missing some of the mechanism to carry the phonograph platform and lower the door etc.I have been looking for a parts cabinet with no luck. My question is if the mechanisms from any other models would interchange. Thank you Terryw49
Welcome to the Phorum. I moved this post into its own thread as it may get more hits here. Icon_smile
Welcome to the Phorum!
Icon_wave
Hi and welcome,
It might be handy to post a few pics of what you've got. Do to the size restrictions on the Phorum you will probably have to resize to fit.
There are currently 9019 online users. [Complete List]
» 1 Member(s) | 9018 Guest(s)
