Capacitor Help
I'll admit, I'm brand new to this and completely ignorant.  I have a '59 Philco record player (G-1606) with the matching speaker (SA-1000).  The record player plays great.  The speaker, however, would only make an extremely loud, high pitched hum.  I removed and repacked a multicapacitor (40/20/10 @ 350WV).  The repack capacitors that I used were a little bigger mdf and voltage but everything I researched said that it would be fine.  I replaced the old with the new and whala! now I have nothing but hiss in the speaker.
I've decided to replace ALL the capacitors but they are only labeled by mfd in the schematic and parts lists.  What WV/VDC should I go with?
Generally 630v caps are the easier to get. You may find the cap across the output transformer maybe higher in voltage. If so use two caps in series @ twice the capacitance to double the voltage rating.
Sorry Terry, caps in series is half the capacitance and twice the voltage.
Yes that is true but what I said was to double the capacitance.
" If so use two caps in series @ twice the capacitance"
So the capacitance divides and the voltage doubles in series if the capacitance is equal between the two caps.
Got it, sorry Terry
Gregb
91H Code 126 Restore
