Another Bing comes off the line
Hey all,
 I have just finished a Philco 46-1201 (Bing Crosby). I started it a long time ago and FINALLY got it finished and off my bench.
I love these as they are easy to restore 99% of the time. You just pop in a new cart and lube the player. The chassis is a little packed but there are only 12 or so caps. Easy yet it took me a year to do.. Ugh....
Video:
https://www.youtube.com/watch?v=LGl7DxF6Vs4
Icon_smile
Nice to know these are easy. I have one I'd like to get to eventually. What do you use for a replacement cart/needle? My cart is dead.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Very nice, Kirk. I've done about 6 of these now, all but one were 46-1201's. It's kind of a pain getting the chassis out, having to unsolder all of those phono wires and the loop antenna but once it's out it is pretty easy to recap. The last one I did I wound up replacing all of the resisitors too.
I had a 48-1201 but it was identical appearance wise to the 1946's. I had heard some of the 1948's had a metal disc replacing the decal above the dial, but I had never seen one, until just this past week when one turned up on 'the bay. I borrowed a pic from it to show what the disc looks like.
Thanks Jeff,
The video explains the cart.. I used a P51-3, It is a perfect and the sound is great.
Greg, I have perfected the art of not removing the chassis. I pull it out of the holes and turn it counter clockwise while flipping it. Then do the recap right in the cabinet.. Works every time but once I broke an antenna wire. I'm into lazy ways, Icon_lol
Icon_smile
I have a Canadian version, but I put it in drydock as I couldn't get the dial to track properly after trying to align it, and became frustrated. I may have to revisit it in future. I don't think that the mercury switch is functional anymore either so if it can't be revived I will have to come up with a substitute like a micro switch.
There are currently 10056 online users. [Complete List]
» 2 Member(s) | 10054 Guest(s)
