Threads: 44
City: Menlo Park
State, Province, Country: CA
Good project Ron, I've enjoyed reading the progress so far - and look forward to the next installment. Marantz equipment is almost always worthy of saving, but projects that don't stay fixed are taxing.
A couple of years ago, I came by a Dynaco ST400. One channel was kaput, so I went about recapping the driver boards, replacing all the driver transistors, and the outputs. It worked like a charm until next morning, when I was greeted with "Kapow!" at switch-on. The cause was the collapse of the plastic bushings used to mount the driver transistors to the heat sink. That was the sound of a fairly inexpensive project getting more costly. Time to do replace all the drivers and outputs again... with new bushings. This fixed the issue, although I have yet to find a use for this nice amplifier.
I wish you well, and hope you are soon back at this project.
Cheers,
Ed
Thanks Ed.
With one more day (tomorrow) before the next chemo session, I got busy this afternoon and finished replacing electrolytics in the replacement 4230 tuner board.
For electrolytics rated at 1 uF or lower, I replaced those with film. You can see those as red or ivory boxes mounted on the board.
The replacement left channel audio output board is waiting for some 330 ohm resistors, but is otherwise finished.
I still need to replace the audio output transistors, which mount to a large heatsink which is then attached to the audio output board by way of four screws and several wires. I have the transistors.
Next time...in a week and a half or so. By then the resistors will be here.
So...
Since my last post, I have received 330 ohm resistors, a couple NOS TCG (NTE) 1230 multiplex decoder ICs, and some 16 pin DIP IC sockets.
This evening, I finally felt good enough to get back to the Marantz boards.
In short order, I had removed the original LA3310 multiplex decoder IC and replaced it with a 16 pin DIP IC socket and a NOS TGC (NTE) 1230 IC.
I wanted to use the socket to make any future replacement of the IC nice and easy. I had read that this IC may have been the cause of loss of FM in the original tuner board, so I wanted to make sure the IC in this board was replaced. I did the same thing in a Lafayette solid state receiver I have. Adding a DIP IC socket did no harm to the receiver, it works fine and if replacement of the IC is ever needed, it will be a breeze (assuming the IC is still available in that future time).
The tuner board is now ready for installation in the 4230.
Then, I turned my attention to what will be the replacement left channel audio output board.
I stuffed it with 330 ohm resistors. I found that I had forgotten to install two 10 ohm resistors; these, too, were installed.
The board itself is now ready.
All that remains is to replace the audio output transistors and wire them into the left channel audio output board.
Then comes the fun of pulling the current left channel audio output assembly and replacing it with this one, removing and resoldering about a million wires in the process. Then lather, rinse and repeat for the tuner board.
Keeping fingers crossed...
P.S. I plan to rebuild the original tuner board in the same manner as I did this one, in case I ever need it. I have so much time and $$$ tied up in this Marantz that I would never get a fraction of it back, so it's a keeper.
Threads: 562
Ron, in case you don't wear antistatic bracelet when handling the IC - do wear it.
100% correct and I knew that - but I forgot to do so last night!
Oh well. I'll try it anyway. If it doesn't work it will be easy to replace now that it has a socket. I have one more IC that was intended for the original tuner board that I can use if necessary. Also, NTE 1230 ICs are still in production. Not real cheap at $10-11 each but still available.
Threads: 562
Well, they have some resilience, so just touching them or even zapping a bit does not necessarily destroy them, which is good news, but some discharges are worse than others (human model is 150pF / 8kV) and this winter is pretty dry, I keep getting zapped at work. So in the winter I always put the bracelet on when doing stuff with boards.
Makes perfect sense. Although (knock on wood) I have yet to be zapped in the basement this winter. And I wear rubber/plastic-soled shoes (either tennis shoes or slippers) when in the basement. The concrete floor is too bloody cold to go barefoot or just in socks.
Threads: 562
When I work in the basement, I run my addition's furnace (it has one register in the workshop room) full time (else it practically does not have to run as I keep the door in addition open and the temp there stays around 65F due to the main part of the house air getting in, except during bad cold spells when I know I have to run it or else something will freeze), and then on top of that I run space heater 3ft from where I stand.
And even with that I do not go there often. It is uncomfortable.
Since my workbench is in the basement, I don't have a choice but to go down there if I want to work on anything.
I run a space heater under the bench. It helps a lot. The house's recirculating water heat system has (only) one radiator in the basement, about 10-12 or so feet from the workbench.
Upstairs, the radiators are in place of wallboard, mostly on the outer walls of the rooms - one exception being the kitchen where the radiators are along an interior wall. The system keeps the upstairs warm unless the outside temperature falls - and stays - below 20 degrees for days at a time.
Threads: 40
City: Lehighton
State, Province, Country: PA
Perhaps a small fan blowing across that basement radiator would help circulate some heat. I had a friend who replaced the basement radiator with a large truck radiator and mounted a fan behind it controlled by a heat sensor. When the radiator warmed up the fan kicked on. It kept the whole basement comfortable.
I like that idea, Larry. I don't know if I can implement a fan solution, though, the way it is made.
Now back to the Marantz...
I installed the recapped tuner board, burning and severing the dial cord in the process.
I then hooked up a makeshift FM antenna and plugged in some headphones, and tried it out.
The result:
AM is dead. FM is working but only in mono. And in FM, the signal strength meter is not working (but the center channel meter is).
I think I'm ready to throw in the towel on this one.
[Video: https://youtu.be/_VrFV5r8cs0]
Threads: 15
City: Weymouth Ma
I have a Marantz 22 waiting in the cellar .One channel has low output and it appears to be the pre amp board but I am in no hurry to do the work. I recently did find a good article on line which will help me get thru it.
Henry
Threads: 55
City: Lexington, KY
(03-10-2019, 04:24 PM)Ron Ramirez Wrote: .........I think I'm ready to throw in the towel on this one.....
Sleep on it a few days or weeks Ron and maybe you'll get an idea or two.
Once Terry started taking in modern receivers he realized he was in over his head. Between parts availability, his unfamiliarity with the solid state circuits, and lack readily of available documentation left him with more than one stack of receivers. He still has over a dozen lined up in his basement that he'll never get to, but that's another story.
Wise advice indeed, John, thanks. I am going to recap the original tuner board and try it out. The replacement tuner board seems to be in need of a serious realignment on FM. No idea why AM is dead on the replacement board.
Threads: 11
City: Black Mountain, NC
Ron,
Sometimes those old Phenolic pc boards can develop hidden leakage paths that will drive you mad.
Hope that's not the case.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
Var resistor id
Var resistor id
Var resistor id
Its a Sylvania 400 oscilloscope. here is a clip of r-100. Would be nice to know the current required. Not listed in part...Martinj — 02:10 PM |
Thanks Richard. I hope you enjoy it.
Here I have created an English section on the history of radio with videos in Engl...RadioSvit — 10:23 AM |
Hello RadioSvit,
first all happy new year !
I will watch your new videos this week.
Sincerely Richardradiorich — 09:19 AM |
There are currently 9234 online users. [Complete List] » 1 Member(s) | 9233 Guest(s)
