Nope, that only goes down to 140 MHz which is way too high in frequency for AM/SW radio work. You need something that will tune as low as 260 kHz for your IF plus the standard AM band and SW frequencies, up to around 30 MHz.
How about this:
https://www.parts-express.com/parts-expr...r--390-600
$164.80 but it is brand new and you would not have to worry about rebuilding, recalibration, etc., which you would have to deal with if you bought an old, used generator.
Threads: 114
City: Sneedville, TN
Ron, I made the mistake of buying one like that. It didn't work very well right from the outset, and crapped out within a year. I now use an old Heathkit, which works VERY well and reliably. All I did to it was replace the main filter condenser. I use a digital readout Grundig S350DLto cross check the frequency I am putting out. Very accurate. No more problems.
Deleted.
Threads: 5
City: Woodland, CA.
That wasnt me who replied to you Ron..
Its true ive never owned or used an RF signal generator. I did locate one nearby this weekend, will be here later this week.. I am still seeking a budget frequency counter so i can "keep it in the zone" as i tune....
Threads: 46
City: Gap Mills Wv 24941
(02-08-2019, 10:48 AM)Ron Ramirez Wrote: How about this:
so,,,
why is that signal gen the same look as "FORDHAM"??
I think its me but i can not seem to manage to get a stable frequency out of it once i get around 35mgHz and higher.
i would really like to know if mine is broke or if its me that is using it wrong,,, im thinking for the higher freq, i need external modulation.
i have the book on it as well,,
The way i know the signal is unstable is by using my frequency counter.
this unit also has the same specs as mine.
just asking,, not hijacking the thread or anything.........
scott
(02-10-2019, 03:18 AM)Stall-U-Rated Wrote: That wasnt me who replied to you Ron..
Sorry, that's what I get for posting right after chemo...it really does affect one's thinking
Threads: 5
City: Woodland, CA.
Hehe, No sweat Ron
So i went to ebay and got my hands on a GW model GRG-450B signal generator. Hooked it up and im getting tone..
Still a few things to get before i undertake the alignment procedure, however, i have a few questions:
1.. Is there an alignment mark on the radio dial scale to make sure its synced with its tuner?
2.. Will this generator require a .1 cap when attaching it to the grid cap of the tube?
3.. Any way to tell if the two "DO NOT ADJUST" condensers on the tuner have been or havent been adjusted?
4.. Will those tiny $10 signal counters they sell on ebay work with my generator or will they lack the range?
Thank you for any info you can give me concerning my radio or generator..
(This post was last modified: 02-16-2019, 02:53 AM by Stall-U-Rated.)
Threads: 2
City: New York
State, Province, Country: New York
(01-26-2019, 12:52 AM)Stall-U-Rated Wrote: Thanks for the link Radioroslyn, as soon as they answer the question i posted them about item t03, ill place the order (quiet so far)...
Can you post the part no. that you ordered? Need a set (6?) of these myself.
Just to confirm, these are for mounting the big tuning condenser, correct?
Matthew W. Woodruff
Threads: 5
City: Woodland, CA.
Click on the link that Radioroslyn sent me prior to the message you quoted this from, scroll down the page and its listed as "tuner support" (Item t03) is listed beneath a picture of 2 mounts next to a penny. Although there are 2 pictured, they are sold singular. These are what my 16b required for the big tuning condenser and i had to order 6 of them (3 top and 3 bottom)...
Hope this helps..
Threads: 5
City: Woodland, CA.
My dial doesnt appear to match the frequencies i am receiving, Will the alignment procedure cure this, or do i have to make any special adjustments before i begin?
Anyone have answers to post 83 before i proceed?
Thanks..
Threads: 44
City: Menlo Park
State, Province, Country: CA
Yes - use a cap to protect the signal generator. Better still add Zener diode protection, as recommended to me:
Threads: 44
City: Menlo Park
Oh dear... I typed a long post reply to this thread and only one line was uploaded!
Once again, here are my answers
I set the dial so that the line at (beyond) the low end of the scale was aligned with the pointer when the tuning capacitor was fully meshed.
For the dial setting work, I didn't connect the generator directly - a wire near the antenna terminal is often good enough to provide a signal that can be used. This is especially true of the signal generator can be modulated.
I never touched the "do not adjust" caps, so cannot comment on their effect.
One purpose of the alignment is indeed to ensure that the dial reads correctly, and stations appear where they should My (5 band set) dial is good except on the 4th and 5th high shortwave bands. Setting these is a compromise, and for some reason, I could not get both dial readings perfect, although reception is good.
Yes, the ebay frequency counters are great for adding digital readout to a signal generator.
Threads: 5
City: Woodland, CA.
Thanks Ed for your detailed response
You helped confirm my dial is set to match the tuning gang from end-end and my frequencies are a tad off....
Good to know those teeny counters on ebay from China will work with my RF generator.
Ive been reading the tuning procedure for my radio and been watching youtube offerings on the subject, so im feeling a bit more confident on doing my FIRST ALIGNMENT... I mostly work on tvs and just began doing the odd radio or so to keep it interesting....
My concern was what to do when the instructions say to set the radio dial to a SPECIFIC point to hear the tone and if i would be able to if my tuner was off a bit.
Since my 5 band radio is functioning and im getting SW and regular stations, in gonna assume the 2 DO NOT TOUCH screws on the tuning gang are untouched... I was curious if anybody ever encountered a tampered one and if there was a remedy?
Well, gotta order some insulated tools and get a counter and ill be ready to dig in....
Thanks again
Threads: 44
City: Menlo Park
Well, one thing you can do for the dial setting, is set the generator to the proper frequency called in the instructions, then tune the radio until you hear it. Of course the dial will most likely not be at the proper point - but this will tell you how much error there is. Then you can adjust the appropriate oscillator trimmer, retune the radio, rinse-repeat until you've got the dial reading in the right place.
Otherwise, if the radio is picking up the generator well enough, and the dial is only a little off, usually you can find it by adjusting the trimmer.
On Short-wave bands, it is sometimes possible to tune the generator in two places on the dial. One is correct, the other is the "image", where the set is tuned 2x the intermediate frequency from the proper dial reading for the signal. A bit of care is required that the proper signal is used, but the image signal should be weaker than the wanted signal.
I'll have another look at the schematic, to see what the "Do not touch" trimmers do, and how much trouble one might cause if they were adjusted by accident.
Cheers
Ed
Users browsing this thread: 16 Guest(s)
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
There are currently 2960 online users. [Complete List] » 3 Member(s) | 2957 Guest(s)
