Philco 42-350 dial pointer
Threads: 22
City: Kewanee
State, Province, Country: Illinois
Just sent the photos. If you think it will work for you, you are welcome to have it. Glad to help.
Gregg
Threads: 7
City: Mason
State, Province, Country: OH
Gregg - I can't tell from the photo does it slide along a flat metal back plate?
Threads: 22
City: Kewanee
Terry I sent a few more pics. It slid across a glass dial. The top tee section where the dial cord runs through it sat on the top edge of the glass dial. The needle is slightly offset from the tee to make up for the thickness of the glass dial.
Gregg
Threads: 22
City: Kewanee
I just sent a pic of it sitting on the glass dial to give you a better idea of how it was.
Gregg
Threads: 7
City: Mason
Just got them.
I don't see any kind of notch or groove that would fit the metal plate I have but it the needle is certainly long enough.
Even if I have to "Frankenstein" into something I can use I think you at least solved the actual needle part of all this.
If you have a chance can you mail it to: Terry Lett 309 Four Seasons Drive Mason OH 45040?
I really appreciate your help on this. I was making such good progress on the rest of the radio until I hit this snag.
Thanks again Gregg!
Threads: 22
City: Kewanee
Absolutely, I'll drop it in the mail tomorrow. Like I said if you can make it work, give it a shot. If you can't, throw it in a drawer like I did.
Gregg
Threads: 7
City: Mason
Threads: 22
City: Kewanee
Terry I mailed the pointer today, so you should have it Tuesday or Wednesday. I hope it works out for you.
Gregg
Threads: 7
City: Mason
I can't thank you enough.
I'm sure I can make it work. The real challenge will probably end up stringing the new assembly.
Dial stringing is like slow torture.
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
