Missing legs?
Seller says he can't find a model number, I can't find this in any galleries. Looks like it might have been a low-boy at one time. Ron? Or anyone?
Pat
[Image: https://oi1367.photobucket.com/albums/r7...a1xqyx.jpg]
That is not an original Philco factory cabinet. And, yes, it looks like it once had legs which have been cut off.
It looks like either a 70 or 71 chassis. If it's cheap enough, buy it and have Steve Davis make a nice new reproduction cathedral cabinet for it. Icon_smile
(04-05-2019, 08:16 AM)Ron Ramirez Wrote:  That is not an original Philco factory cabinet. And, yes, it looks like it once had legs which have been cut off.
Thanks, Ron. You saved me some money. Would have been a 4 hour round trip drive anyway.
I like the amputee cabinet the 70 looks at home in it can you buy it for me? lol
I think a console 70 or similar cabinet refinished was being sold during this Kutztown show.
They are not hard to find (meaning consoles).
There are currently 10443 online users. [Complete List]
» 2 Member(s) | 10441 Guest(s)
