Had to move some of my web site
Information
As Earthlink essentially killed my "free" web space, I recreated the missing web pages I had there.  And they are now at my domain www.wa2ise.com    Most of what I had on Earthlink and Netcom is now at http://www.wa2ise.com/netcom/netcomhomepage.htm   I used the Wayback Machine to recover most of this material.
Congratulations on the new pages. Lots of very interesting and useful information there. Thanks for posting.
There are currently 6544 online users. [Complete List]
» 3 Member(s) | 6541 Guest(s)
