To Floor or to table,...that is the question. ;-)
635 CSX , . . .  is it a tabletop radio or a floor model?  I can't tell.   Icon_eh
Chairside!
Floor model made to sit next to your recliner... Icon_smile
Aaaaaah...yes...  I loooove the chairsides !  This one looks a tad different and I couldn't tell how large it was by the pic in the gallery.  Thanks bud.   Icon_lol
I was not too sure so I googled it Icon_lol
A lot of the early Philco chairside sets (around 1933/34)used a large separate spkr in a large wooden cabinet. Ones that come to mind the 14LZX,19LZX, 91RX, 14,16, 17, &18RX. Have had a few or them over the yrs.
Yes Terry, . . .I've noticed one or two like that in the gallery.  Elegant units to moi.   Heart
Icon_wink
There are currently 10518 online users. [Complete List]
» 2 Member(s) | 10516 Guest(s)
