What do I have here?
Hello to all,
While out digging thru a few antique stores today, I ran across this little gem. It is a small bakelite with leatherette panels and a brass or gold colored grill over the speaker.  It is AC powered, no battery compartment.  AM broadcast band only. It opens up, as shown.  The chassis appears to be encased in a perforated metallic case within the bakelite shell. The loop antenna is attached to the back side.  The controls are two thumb wheels on the top, front area.  I have never seen anything like it. It does have the Philco name on the front.  The paper tag on the inside is almost completely destroyed from damage by cord storage.
Any ideas what I might have here? Model no. etc.?
Thanks for looking.
Chris H
N9WHH
https://philcoradio.com/gallery2/1949a/#Model_49-603
Standard ac/dc set w/an odd cabinet.
Thank you Terry. I looked around but couldn’t find anything that looked like it. It appears to be in pretty good shape and should clean up well. I figured it was an AC/DC chassis.
Thanks, again.
Chris H
N9WHH
There are currently 10549 online users. [Complete List]
» 2 Member(s) | 10547 Guest(s)
