Radio tuning belts: has anyone used the vendor before?
https://www.ebay.com/itm/Quality-radio-b...Sw9nJcqIZA
As we all know, Adams Radio is no longer.
Has anyone used the belts from this vendor?
Or who filled Al's shoes after he decided to retire?
https://www.qualityradiobelts.com/index.html
I think that he took over.
I bought a belt from him for my Zenith 12S471.  It fit fine.
The same guy, right? In Bristol RI.
Yes,
Ted has taken over and his belts are quality...
Icon_smile
There are currently 10469 online users. [Complete List]
» 2 Member(s) | 10467 Guest(s)
