42-PT94 escutcheon
Is a reproduction available for sale or no?
Nope. Kirk had made some up but I'm pretty sure he has sold all of them.
Kirk said it costed him more than he could charge for it (3D-printing).
There are currently 10076 online users. [Complete List]
» 2 Member(s) | 10074 Guest(s)
