7af7 in 46-1226 code 122
what is the resistor value from pin 2 to 7 on a 7af7 in a 46-1226-code 122 it's black and unreadable
thanks
john
2200 ohms, 1/2 watt. Icon_smile
Be sure you replace C405, .05 uF, if you have not already done so; along with replacing all of the paper and electrolytic caps in the radio.
thank you for your help
john
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6227 online users. [Complete List]
» 1 Member(s) | 6226 Guest(s)
