- as mentioned on "recent finds".
I am going to have to limit my lifting to radios that have 10 tubes or less. Getting this on the bench is a REAL pain - -
https://www.russoldradios.com/blog/big-p...stone-116b
Looks great Russ. They are heavy!!
That'll do!!!
Sweet.
Looks fantastic, Russ!
Based on other shouldered 116Bs I've seen, I think you're correct that Van Dyke brown (which looks great on 1934/35 Philcos like the Butterfly) would be too dark on this radio. What you've done there looks spectacular.
-Rodney
You need one of these!
I just got one off eBay and will be scanning it... Some day, lol
Having one would be cool.
 I have quite a few radios w/manuals. Unlike almost everything else, I never did an inventory of which radios have them and which don't. Not that I am the kind of person that reads a manual anyway - -
There are currently 8414 online users. [Complete List]
» 2 Member(s) | 8412 Guest(s)
