Philco 20, 21, 90 or what?
Threads: 1
City: Berryton, Kansas
Threads: 271
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!!
See https://philcoradio.com/gallery2/1931a/#...dels_21_46
Some of the early 21 cabinets used the 20 chassis. Don't want those 20 chassis to go to waste!
Threads: 562
Methinks it is a mongre.
Someone took a 20 chassis, added a 4th knob (the 20 has 3, so whatever that 4th knob does.....a mod in the chassis?) and stuck it into a 90 cabinet.
And no it is not a 21 cabinet with 90 trim, it is a 90 cabinet (the top of the 90 is very characteristic and can always be told from the 70, and the 21 has it like the 70 does).
Threads: 271
City: Wilsonville
Mike, yea it does because its a 21 cabinet with a 20 chassis. They used up the 20 chassis they had when they started the 21 run. Ron has mentioned this in other threads.
Threads: 562
Bob, no it is not a 21 cabinet. It is a 90 cabinet.
And I am not saying this because of the trim from 90 or 4 knobs holes: look at the top. It is a 90 cabinet.
Threads: 1
What about the escutcheon? It's not from a 90, is it?
Threads: 271
City: Wilsonville
Threads: 1
So the top of the 90 is more pointed than the 21, is that what you mean, morzh?
Threads: 268
Hi Robin and welcome to the fray,
I think Mike has the answer. Chassis is a 20. If it were a 21 it would have a large round filter cap. The 20 uses several in a tin can like this chassis. The 90 would have a singe section volume control only the older non avc sets use the dual control. I would suspect the knob on the right is to adjust the tone the 20/21 didn't have that adjustment.
Cabinet is for a 90. The holes for the chassis to the wooden base don't align. The 20/21 only use three bolts the 70/90 uses four.
If you could post a pic or two of the top and bottom of the chassis and the base board that arn't so close up I can a little bit more abt it.
Best Regard's
(This post was last modified: 05-22-2019, 02:35 PM by Radioroslyn.)
Threads: 72
City: Linn Creek, MO
Mike is correct, this is a 90 cabinet. The top of the arch has a little more of a peak than the 21. Also, if you look at the rear, you can see there is about a 1/2 inch space between the chassis and the side of the cabinet and the back edge of the chassis is about an inch from the back of the cabinet. Now, what I cant explain is the shaft spacing. Obviously, a tone control has been added but the spacing of the two outer controls would have to be widened to match the holes in the 90 front panel.
M R Radios C M Tubes
Threads: 271
City: Wilsonville
OK I see it now....I stand corrected by folks that know more than me...
Threads: 562
Robin,
Yes, the 90 cabinet (although some folks say they look the same with 70, only the trim is different) does have a pointier (just a tad) top in addition to the different trim at the bottom, and it makes it a bit more elegant (to me).
Mike is correct - the cabinet is a model 90.
The chassis is a modified model 20, since this one has four control knobs and model 20 only has three (as Mike and others have also pointed out).
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.
I would start from touching Test Point 12 on the sch.
See if you hear hum.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
There are currently 8997 online users. [Complete List] » 2 Member(s) | 8995 Guest(s)
