10 mfd in place of a 6
is that too much? i would use a 8 if i could find one in my stock.
Ur fine.
I'm just trying to be careful my mentor from years ago always told me never go to high in capacitance when replacing electrolytics.
It is possible to raise the B+ in doing this, though generally not a problem. The other issue might be exceeding the rating on the rectifier for a first filter cap such as 10uf for an 80. In this case I would not anticipate any problems.
Depends where. If it's the first filter cap, the B+ will go up, though as Russ said it is not necessarily a problem. The second cap (usually after the field coil) it is not critical at all, wthin reason - the more the better (they probably would use more but at the time larger values were not as widely available).
Well since i read the schematic wrong and this is a 25-40 cycle not the 60 set the first cap is a 10 mfd and the audio is a 6 mfd. So a 10 will be fine.
Jake, your radio is “now” a 60 cycle set. Having said that, 10 uf will still be fine.
M R Radios   C M Tubes
...by that, Steve means that your 50-A will now be operating on 60 cycle (60 Hz) AC. So don't stress it. Icon_smile
Sounds good i hope it likes a pair of 10/10 @ 450
Wow,,long time ,,,RON,,,,soo glad you are still watching all us Kids,,,,,Hope you feel some--what better ,,My Friend
91H Code 126 Restore
There are currently 4089 online users. [Complete List]
» 1 Member(s) | 4088 Guest(s)
