06-01-2019, 08:27 AM
is that too much? i would use a 8 if i could find one in my stock.
10 mfd in place of a 6
06-01-2019, 08:33 AM
Ur fine.
When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
06-01-2019, 08:47 AM
I'm just trying to be careful my mentor from years ago always told me never go to high in capacitance when replacing electrolytics.
06-01-2019, 10:54 AM
It is possible to raise the B+ in doing this, though generally not a problem. The other issue might be exceeding the rating on the rectifier for a first filter cap such as 10uf for an 80. In this case I would not anticipate any problems.
06-01-2019, 11:15 AM
Depends where. If it's the first filter cap, the B+ will go up, though as Russ said it is not necessarily a problem. The second cap (usually after the field coil) it is not critical at all, wthin reason - the more the better (they probably would use more but at the time larger values were not as widely available).
06-01-2019, 11:21 AM
Well since i read the schematic wrong and this is a 25-40 cycle not the 60 set the first cap is a 10 mfd and the audio is a 6 mfd. So a 10 will be fine.
06-01-2019, 01:21 PM
Jake, your radio is “now” a 60 cycle set. Having said that, 10 uf will still be fine.
Steve M R Radios C M Tubes
06-01-2019, 01:39 PM
...by that, Steve means that your 50-A will now be operating on 60 cycle (60 Hz) AC. So don't stress it.
![]() -- Ron Ramirez Ferdinand IN
06-01-2019, 04:35 PM
Sounds good i hope it likes a pair of 10/10 @ 450
06-08-2019, 09:35 PM
Wow,,long time ,,,RON,,,,soo glad you are still watching all us Kids,,,,,Hope you feel some--what better ,,My Friend
« Next Oldest | Next Newest »
Users browsing this thread: 3 Guest(s) |
