47-1227 - Radio will not tune in any stations.
Threads: 3
City: Middletown, PA
State, Province, Country: Pa
I have a Philco model 47-1227. It has been completely restored. All capacitors and resistors have been replaced. The audio works. We get sound from the record player but unable to tune in any stations. Have minis 2.5 volts at osc. tube. osc. tube does not change voltage when tuning dial is changed. No am or fm. Any ideal what's wrong? HELP!!!!!!!!?!
(This post was last modified: 06-09-2019, 06:53 PM by Lucky.)
Threads: 268
Time to break out the signal generator and inject a modulated 455kc signal @ test point A. This is w/the set set up to receive an AM signal and see what you get from the spkr.
Threads: 3
Receive nothing from test point A or when connected to antenna
Threads: 268
Ok inject a 455kc signal @ pin 1 of the 6ba6 and see what you get from the spkr.
Threads: 3
We get nothing from pin 1
Threads: 268
How about pin 6 on the 7R7.
Threads: 3
Pin 6 works with. Get loud tone
Threads: 3
06-09-2019, 08:38 PM
Pin 6 works. Hey loud tone.
(This post was last modified: 06-09-2019, 08:39 PM by Lucky.)
Threads: 268
Ok so you have a problem around the 6BA6. Check the pin voltages according t o the service info. Also be sure the heater is lit.
(This post was last modified: 06-09-2019, 08:46 PM by Radioroslyn.)
Threads: 3
pin 1. -.26 volts
pin 2. 0 volts
pin 3. 0 volts
pin 4. 0 volts
pin 5. 280 volts
pin 6. -1.14 volts
pin 7. .06 volts
Heater is lit
(This post was last modified: 06-09-2019, 09:09 PM by Lucky.)
Threads: 43
City: Brownsville 42210
State, Province, Country: Kentucky
filament should be pin 3 & 4 and pin 6 should be 100v
(This post was last modified: 06-09-2019, 09:48 PM by jake wells.
Edit Reason: error
Threads: 3
pin 3 grounded at center of tube
pin 4 shows 6.6 volts ac
The tube is lit and working
Threads: 43
pin 6 should not be reading -1.14 it should be 100V check the resistors and capacitors in that circuit.
Threads: 3
Will check Tomorrow night.
Threads: 43
Users browsing this thread: 16 Guest(s)
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
There are currently 2947 online users. [Complete List] » 1 Member(s) | 2946 Guest(s)
