Threads: 7
City: Austin
State, Province, Country: Minnesota
im restoring a Philco 42 PT-7 radio for the first time and I’ve heard i could get shocked if I’m not careful.. What are my real dangers with it unplugged? I also heard on YouTube that paper capacitors should just be automatically replaced because they’ll likely go out soon if they’re not already. Can I just clip the wires on them (provided I take plenty of pics beforehand) without any dangers? My snips do have plastic handles so I should be good as far as that part goes… The guy who I bought it from on eBay said it did light up but no sound came out. Any guesses to what maybe wrong? I’m guessing likely a bad tube? But that’s only a guess, I have not attempted to plug it in myself I downloaded the schematic for it but I’m not sure how to read it. I don’t want any of my faults to keep me from trying to restore this thing though.
Any help would be nice!
Adam
Threads: 268
Hi Adam,
Very little. Would be a freak sort of accident to get shocked.
>I’m guessing likely a bad tube? [Image: https://philcoradio.com/phorum/images/sm...on_lol.gif][Image: https://philcoradio.com/phorum/images/sm...n_evil.gif]
More than likely there will be several issues to correct. A tube or two may be part of the problem. Unless your set came from CA you are probably going to have decaying rubber wire which can be a bit of a pain to replace
Not sure what you are saying. Is it just schematics w/vacuum tubes or you have no clue as to how to decipher what you are looking at on any schematic?
http://www.nostalgiaair.org/pagesbymodel...013568.pdf
(This post was last modified: 06-21-2019, 08:10 PM by Radioroslyn.)
Threads: 569
Not sure I got you right: are you implying snipping wires while plugged and powered? If yes, you are having some serious issues with understanding safety and should not attempt at repairs until familiarizing yourself with rules of it.
If not then why the plastic handles matter?
Threads: 7
City: Austin
Thanks for the info, Terry. The schematic i downloaded and printed off is the exact one you attached. I think I’m starting to understand it better
Threads: 7
City: Austin
No, I’m not that crazy.. Of course it’ll be unplugged before I even attempt to replace anything, I’m only 40.. I want to live longer! Lol
Threads: 7
City: Austin
I just know that some capacitors can hold a lethal charge even when the item they’re attached to isnt even plugged In, that was main concern and that’s why I mentioned the rubber grips on my tools so I should be good I’m thinking as far as that goes. The table I’m working on isn’t metal either
Threads: 337
City: lawrenceville nj
I would presume you are not familiar with electronics ?
do you know how to solder ?
read schematics ?
all round paper caps should be replaced so should electrolytics
take lot of good pics for reference
and ask a lot of questions
sam
Threads: 242
City: West Bend, Wisconsin
While the little pre-war transitones are relatively simple in design, for a first attempt at restoring a radio it may not be the best choice due to the extremely cramped chassis and crumbling wire wrapped around everything. Be aware that any wire that gets disturbed will more than likely have its coating crumbling off, leaving you with a bare wire. Not good. Totally rewiring the radio to replace ALL of the crumbling wire would be preferred (see Ron's thread for a somewhat similar set up: https://philcoradio.com/phorum/showthread.php?tid=19779) but that would probably be above the skill level of someone just starting out. You may opt to just replace or sleeve the ones that are bare with shrink tubing, or at the very least use some liquid tape on a toothpick to coat the bare spots on the wire. Good luck!
Threads: 72
City: Linn Creek, MO
If your radio is unplugged, it is safe to work on. The tubes are still hot the moment the power is turned off and will continue to conduct for a second or two, this will discharge the capacitors.
M R Radios C M Tubes
Threads: 569
.....unless the radio was plugged in without the speaker, in which case the charge persists longer and we are all guilty of doing that every once in a while
Or the transformer is open.
Threads: 7
City: Austin
Do I change the blue capacitor shown in the pic? And if so, with what? It says 20 + 20 MFD on it..
Thanks
(This post was last modified: 06-23-2019, 04:18 PM by Arohn19.)
Threads: 7
City: Austin
For some reason the pic isn’t posting
Threads: 268
Check the size of the pic you may have to resize it (smaller) the Phorum doesn't do it automatically.
Threads: 15
City: Fort Worth
State, Province, Country: TX
What radio are you working on? What does the schematic or parts list show for electrolytic capacitors? The 20 + 20 means there are two 20 MFD electrolytic capacitors present. If the part is original or old, it would need to be replaced. Easiest way to do that is with two separate 20 or 22 MFD electrolytic capacitors of an appropriate voltage rating.
Two separate threads started by the OP have been merged into one.
Arohn19, separate threads on the same subject are not allowed per Phorum rules.
https://philcoradio.com/phorum/showthread.php?tid=4586
Please read and familiarize yourself with the Rules. Thanks.
Users browsing this thread: 16 Guest(s)
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
There are currently 4247 online users. [Complete List] » 1 Member(s) | 4246 Guest(s)
