Threads: 7
City: Austin
State, Province, Country: Minnesota
I read on a resource website that I can change all my paper/wax capacitors to film capacitors of a higher volt rating.. Did I understand that right? And can I find the one with the highest VDC and switch them all out to film capacitors of a equal VDC or higher? I think I am finally beginning to understand this. I’ve got a learning disability so it takes me longer to understand stuff (especially when written and on here. I’m more of a visual learner so, please be patient with me guys.  I’ll probably be asking some more questions
Adam
Threads: 72
City: Linn Creek, MO
Adam, I am also one that learns by doing.
You can use 630 volt film capacitors to replace all the paper capacitors in your radio. There may be an exception on some radios such as a cap connected to the primary of the output transformer. You can use the “orange dip “ type or the yellow tubular ones, it doesn’t make any difference at all. There are several dealers selling capacitors, including a couple of members of the Phorum
M R Radios C M Tubes
Threads: 7
City: Austin
Thank you Steve! That makes it a lot easier to restore this thing, hopefully I can get this playing again soon. A few of the paper capacitors look blown to me anyway but, I’ve read not to bother with them regardless and just replace them. The speaker maybe bad too but, I won’t know that until I’ve recapped everything
Threads: 7
City: Austin
Steve, do I need to get them all in the different Ufs that the schematic calls for or can I just use the highest one it calls for to cover all the ranges?
Threads: 271
City: Wilsonville
State, Province, Country: OR
Adam, you should get the film capacitors with capacitance (uF) values close to the values that are in the radio or on the schematic. Modern capacitors do not come in some of the odd values that used to be used but you can usually get something close. Close is usually good enough.
Threads: 72
Yes, an example .05 is no longer a standard value, in this case you would use .047 or if your radio has a .02 you would use a .022. As Bob said close will be good enough.
(This post was last modified: 06-23-2019, 08:29 AM by Steve Davis.)
Threads: 7
City: Austin
Thanks for the help guys!
Threads: 7
City: Austin
Steve, my schematic saids one is .01uf.. Would I use a .22uf in that case too? I’m assuming I would
Threads: 7
City: Austin
No, use a new .01 uF.
This might help:
If the schematic reads - Use
.001 uF - .001 uF
.002 uF - .0022 uF
.003 uF - .0033 uF
.005 uF - .0047 uF
.01 uF - .01 uF
.02 uF - .022 uF
.025 uF - .022 uF
.03 uF - .033 uF
.05 uF - .047 uF
0.1 uF - 0.1 uF
0.2 uF - 0.22 uF
0.25 uF - 0.22 uF
0.3 uF - 0.33 uF
0.5 uF - 0.47 uF
Threads: 569
0.07uF - 0.068uF.
Threads: 7
City: Austin
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
There are currently 4073 online users. [Complete List] » 3 Member(s) | 4070 Guest(s)
