12-09-2010, 05:44 PM
The power/ primary transforner(T100) leaked wax and caught fire. I want to replace it but the schematic gives no details on what it is. Where can I find a replacement?
Thanks
Thanks
47-1230 transformer
Thanks
12-09-2010, 06:26 PM
I may be able to help when I get home this evening. Will look up the Philco part number in the Model 47-1230 Service Bulletin and then check all my post-war Philco Parts Catalogues for the specs.
Chuck Chuck Schwark, The Philco Repair Bench [Image: http://www.philcorepairbench.com/images/philog3tiny.gif] http://www.philcorepairbench.com
12-09-2010, 06:55 PM
Chuck thanks for the reply , the original part for t100 is 32-8248 ,if that helps
12-09-2010, 08:25 PM
Ellis,
I didn't need the transformer part number, as it is listed in the parts list of the Service Bulletin, but that is correct. The 32-8248 is a vertical mounting type. with mounting centers of 2-1/2" x 2-1/4" Height = 3-7/8" / Length = 3-1/2" / Width = 3-7/32" Note: The voltages listed are for a line voltage of 115 volts (1947 remember). Primary - 115 VAC Secondaries: High Voltage - 675 VAC @ 100 ma., center-tapped (330v - 0 - 330v) Rectifier - 5 VAC @ 2 Amp Filament #1 - 6.4 VAC @ 2.5 Amp Filament #2 - 6.4 VAC @ 0.6 Amp, center-tapped (Used expressly for the two audio output tubes) Check out PlayThings of Past ( http://oldradioparts.com, and Radio Daze ( http://radiodaze.com ) for a replacement transformers. Also use your favorite online aution and wanted listings for a junker chassis. Regards, Chuck Chuck Schwark, The Philco Repair Bench [Image: http://www.philcorepairbench.com/images/philog3tiny.gif] http://www.philcorepairbench.com
12-10-2010, 10:12 PM
I have the Philco part.
It is in a box, however I have not checked it. It may be a repack or used. Either way, I will test it and guarantee it to be good before shipping. It would be $20 including shipping. Don
« Next Oldest | Next Newest »
Users browsing this thread: 4 Guest(s) |
