philco 84B
does anyone know the physical dimensions of the e cap 4+8 mfd p/n 30-2013? mine is missing and i need to find something that at least resembles it.
1 5/16" x 4 1/16"
thanks for that. dont suppose anyone knows a possible source of supply? e bay sellers all want a fortune to mail here for some reason. not that it matters much as old ecaps arent sold by physical size!! i plan on stuffing this with two modern e caps is it useful to increase capacitance? and if so how much?
Use a Twist-Lok style cap (large size) and fit it from the bottom of the chassis flange won't clear from the top. 2X 10mfd @ 450v is fine.
[Image: https://www.rfparts.com/media/catalog/pr...OmpES7.jpg]
and i do thank you again!
91H Code 126 Restore
There are currently 2570 online users. [Complete List]
» 2 Member(s) | 2568 Guest(s)
