Model 89 Schematic
Hello All,
My first time posting here.  I'm going to try my luck with a Model 89 Code 121.  I can't find a Code 121 schematic but I do have versions for Code 123 from Philcoradio.com and 89, 89A version 1 from Radiomuseum.com.  These two versions have slight differences but more or less the same.  Is there a version for Code 121?....do you know of one?...or will the versions I have work for my radio?
I understand that Model 89's have many problems to watch out for.  It should be a challenge.
Thanks, Steve
https://philcoradio.com/library/index.ph...-model-89/
Great, this is everything I was looking for. This will really help. Thanks much. I try to learn all I can about a radio before I do anything.
91H Code 126 Restore
There are currently 2524 online users. [Complete List]
» 2 Member(s) | 2522 Guest(s)
